pounds till KG
Konsumentråd
8 svar · 391 visningar · startad av lex_mw
Medlem sedan mars 2001444 inlägg
hur räknar man ut hur mycke 350 pounds e till vanliga KG??
"may the rejn 2000 be with ya"
I got this one. 350lbs=158.757kilos. All kinds of conversions to be found at http://www.sciencemadesimple.com/conversions.html
AngryArmadillo
Visit my homepage. At one time the most popular in Sweden.
http://www.nowhere.nu
kanon
tackar så mycke AngryArmadillo
Medlem sedan apr. 2000642 inlägg
jag tror att ett pound är 0.454 kilogram ungefär. resten får du klara själv :)
PeterSign v 2.3.36
KANON :)
Excellent site Tony! :)
I always have to convert from Celcius to Farenheit and centimeters to inches... or the other way around, since those lazy americans can't convert to more reasonable ways to messure things. ;)
/Petra
If you see someone without a smile, give them yours.
CyberPet, the Imperial system is taking over the Metric, inch by inch... = )
:e
all your base are belong to us!</A>
lex du får sluta titta på filmer Tex Unbrakeble hemma hoss mig
ok kille lyft 350 pund men so han va ju serie jälte ju
Life is free You Can always chose you´r Destiny.
Live Life in Vane Ore in Pain
258 ms totalt · 4 externa anrop · v20260731065814-full.6fe65c25
120 ms — deklarationer (db)
125 ms — ändringar (db)
