Ping
7 svar · 234 visningar · startad av emission
Torr UNIX-humor när den är som bäst.
Kolla den första kundrecensionen
http://www.amazon.com/exec/obidos/tg/stores/detail/-/books/0670672238/glance/1 07-8728883-3442129
[Redigerat av emission den 18 jan 2001]
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for PING:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
Medlem sedan feb. 20001 270 inlägg
Forumledare spekulerar! :e
woodi
Svenska FF1
www.johan-skog.nu
de e humor, de e humor, de e humor. :e
if i'm not back in five minutes, just wait longer.</A>
Medlem sedan dec. 20003 083 inlägg
But even with these problems, The Story About Ping has earned a place on my bookshelf, right between Stevens' Advanced Programming in the Unix Environment, and my dog-eared copy of Dante's seminal work on MS Windows, Inferno. Who can read that passage on the Windows API ("Obscure, profound it was, and nebulous, So that by fixing on its depths my sight -- Nothing whatever I discerned therein."), without shaking their head with deep understanding. But I digress.
MUHAHAHAHA!! Rolig kille det där ... :e
Medlem sedan aug. 20003 742 inlägg
Ha ha vilken recension, får väl göra plats för den i min bokhylla :e
[r]Ha ha nu får jag sluta låta mina inlägg sitta på skärmen en kvart innan jag trycker på posta, så kanske jag någon gång kommer före andra med samma ideér :e
//Alian Luxman=the BabelFish
"Love thine enemies...it really pisses them off."
[Redigerat av Luxman den 18 jan 2001]
tss.. så här ser riktig UNIX humor ut :e
Unix jokes
Q: How many Unix Support staff does it take to screw in a light bulb? A: Read the man page!
Q: How many Support staff does it take to screw in a light bulb? A: None. The bulb was fine; you just forgot to turn the switch on.
Q: Is there a UNIX FORTRAN optomizer? A: Yeah, "rm *.f"
Q: Is there a proper procedure for asking the support staff questions? A: Questions will not be answered by the support staff unless the proper procedure is used.
Q: How do I send electronic mail? A: I'm busy now, please send me e-mail.
Q: Why do support staff email messages always end in quotes no one understands? A: "The way is void" -Musashi
Q: Is there some documentation for the "tn3270" command? A: It's here with a description of emacs vi-mode.
http://www.segfault.org
men bäst är nog iaf: http://www.segfault.org/story.phtml?mode=2&id=3617b576-0680eca0
MVH
/C
"The only source of knowledge is experience"
- Albert Einstein
[Redigerat av stoffe-2k den 18 jan 2001]
På vilket jag naturligtvis måste kontra med;
Tecken på att Windows kommer att krascha snart
Du får höra att Bill Gates månatliga check till Hin Håle kom tillbaka i posten på grund av för lite porto.
Din Palm Pilot börjar vråla "Mayday! Mayday!"
Antingen är det du som inte sett den förut, eller så är det så att ikonen som liknar ett MacIntosh-äpple med en motorsåg är helt ny...
Bill Gates hoppar ur en svart helikopter på din bakgård och erbjuder dig en miljon för att du ska hålla käften stängd.
Skärmsläckaren med de flygande fönstren har ändrats till en bild av zeppelinaren Hindenburg.
Likt gnagarna på ett sjunkande skepp har din mus gjort det enda rätta och har studsat in i rummet bredvid.
Den lilla isbergsikonen blir större och större för var minut.
Din skärmsläckare visar en man som begår självmord genom att trycka ner en skruvmejsel i en flygande brödrost.
En airbag vecklas ut från monitorfoten och slår upp i ditt ansikte.
http://www.skrattnet.com/microsoft/
124 ms — deklarationer (db)
120 ms — ändringar (db)
