Regler för att vara människa...
Livsfrågor & relationer
2 svar · 127 visningar · startad av nanne
Medlem sedan dec. 19991 749 inlägg
Regler för en människa:
Du är själv en ande i en kropp flicka/pojke.
Kroppen är ditt hem för en period.
1. You will recive a body.
You may like it or hate it,
but it will be yours for the entire period this time around.
2. You will learn lessons.
You are enrolled in a full time,
informal school called life.
Each day in this school
you will have the opportunity to learn lessons.
You may like the lessons or think them irrelevant and stupied.
3. There are no mistakes, only lessons.
Growth is a process of trail and error, experimentation.
The ”failed” experiments are such much a part of the process
as the experiments that ultimately ”work”.
4. A lesson is repeated until it is learned.
A lesson will be presented to you in various forms until you have learned it.
Then you can go on to the next lesson.
5. Learning lessons does not end.
There is no part of life that does not contain its lessons.
If you are alive, there are lessons to be learned.
6. ”There” is no better than ”here”.
When your ”there” has become ”here”
you will simply obtain another ”there”
that again looks better than ”here”.
7. Others are merely mirrors of you.
You cannot love or hate something about another person
unless it reflects to you something you love or hate about yourself.
8. What you make of your life is up to you.
You have all the tools and resources you need;
what you do with them is up to you.
The choice is yours.
9. The answers lie inside you.
The answers to life´s questions lie inside you.
All you need to do is look, listen and trust.
10. You will forget all this.
"Information wants to be free -- because it is now so easy to copy and distribute casually -- and information wants to be expensive -- because in an Information Age, nothing is so valuable as the right information at the right time."
- John Perry Barlow
nanne.net
:e
Function onLick(name)
Punch.name(in_the_ear)
End Function
Jourhavande Vide
Medlem sedan dec. 20011 685 inlägg
:e
Jag är lite borta men lämna ett meddelande
535 ms totalt · 4 externa anrop · v20260731065814-full.86ec41c2
126 ms — deklarationer (db)
124 ms — hämta statistik (db)
239 ms — hämta tråd, inlägg och bilagor (db)
168 ms — ändringar (db)
