Lite natthumor...
3 svar · 275 visningar · startad av Vide
Hittade en liten artikel på laffatorium:
Software Conflicts
Last year a friend of mine upgraded GirlFriend 1.0 to Wife 1.0 and found
that it's a memory hog leaving very little system resources for other
applications. He is only now noticing that Wife 1.0 also is spawning
Child-Processes which are further consuming valuable resources. No mention
of this particular phenomena was included in the product brochure or the
documentation, though other users have informed him that this is to be
expected due to the nature of the application. Not only that, Wife 1.0
installs itself such that it is always launched at system initialization
where it can monitor all other system activity. He's finding that some
applications such as PokerNight 10.3, BeerBash 2.5, and PubNight 7.0 are
no longer able to run in the system at all, crashing the system when
selected (even though they always worked fine before).
At installation, Wife 1.0 provides no option as to the installation of
undesired Plug-Ins such as MotherInLaw 55.8 and BrotherInLaw Beta release.
Also, system performance seems to diminish with each passing day.
The features he'd like to see in the upcoming Wife 2.0 include:
\- A"Don't remind me again" button
\- Minimize button
\- An install shield feature that allows Wife 2.0 to be
  installed with the option to uninstall at anytime
  without the loss of cache and other  system resources.
   \- An option to run the network driver in promiscuous
   mode which would allow the systems hardware
   probe feature to be much more useful.
I myself decided to avoid all of the headaches associated with Wife 1.0 by
sticking with Girlfriend 2.0. Even here, however, I found many problems.
Apparently you cannot install Girlfriend 2.0 on top of Girlfriend 1.0. You
must uninstal uninstall Girlfriend 1.0 first. Other users say this is a long
standing bug which I should have been aware of. Apparently the versions of
Girlfriend have conflicts over shared use of the I/O port. You think they
would have fixed such a stupid bug by now. To make matters worse, The
uninstall
program for Girlfriend 1.0 doesn't work very well leaving undesirable
traces of the application in the system.
Another thing that sucks -- all versions of Girlfriend continually pop-up
little annoying messages about the advantages of upgrading to Wife 1.0
BUG WARNING
Wife 1.0 has an undocumented bug. If you try to install Mistress 1.1 before
uninstalling Wife 1.0, Wife 1.0 will delete MSMoney files before doing the
uninstall itself. Then Mistress 1.1 will refuse to install, claiming
insufficient resources.
BUG WORK-AROUNDS
To avoid the above bug, try installing Mistress 1.1 on a different system
and never run any file transfer applications such as LapLink 6.0. Also, beware
of similar shareware applications that have been known to carry viruses
that may affect Wife 1.0.
Another solution would be to run Mistress 1.0 via a UseNet provider under
an anonymous name. Here again, beware of the viruses which can accidentally be
downloaded from the UseNet.
:e :e :e :e
       (o o)
-oo0-(_)-0oo-----
webeye.nu *hem*
vide@4sale.se
[Redigerat av Vide den 21 maj 2000]
...Och för er som inte kan engelska:
Flickvän 3.2
Förra året så uppgraderade min kompis sin FlickVän 3.2 till FlickVänPlus 1.0 (marknadsnamn: Fästmö 1.0). Nyligen så uppgraderade han sin Fästmö 1.0 till Hustru 1.0 och det var en grej som verkligen tog plats. Hustru 1.0 har tagit alla hans resurser, och Hustru 1.0 måste konsulteras innan man kan göra någoting annat. Och även om han inte bad om det så kom Hustru 1.0 med insticksprogram som Svärmor 2.0 och Måg 1.0.
Men inte bara det, Hustru 1.0 installerar sig själv på ett sådant sätt att det alltid är aktivt och kan övervaka alla andra systemaktiviteter.
Hustru 1.0 skapar även konflikter då program som Pokerkväll 10.3, Ölhävning 2.5 och Pubrunda 7.0 försöker köras. Hela systemet kraschar då och och felmeddelandet "DU HAR JUST UTFÖRT EN FÖRBJUDEN ÅTGÄRD" uppstår, fast det har gått att köra dessa program tidigare.
Detta är några finesser som jag skulle vilja se i uppkommande versionen FlickVän 4.0:
- En 'Fråga inte detta igen'-knapp
- Minimeringsfunktion
- Avstängningsfunktion
- Ett installationskydd så att FlickVän 4.0 vid önskan kan avinstalleras totalt, utan att du ska förlora några resurser
Jag försökte köra FlickVän 2.0 med FlickVän 1.0 fortfarande installerad, och de försökte använda samma I/O-port varpå det blev konflikter. Då försökte jag avinstallera Flickvän 1.0, men hade inte ett avinstallationsprogram. Jag försökte då avinstallera det för hand, men det la filer i min systemkatalog. En annan sak som är kasst med samtliga versioner av FlickVän är att de är totalt objektorienterade och kräver hårdvara med guldpläterade kontakter. En annan sak som kan skapa enorm irritation är de ständiga pop-up meddelandena som FlickVän skickar som handlar om fördelarna med att uppgradera till Hustru 1.0.
------ Buggvarning! ------
Hustru 1.0 har en odokumenterad bugg. Om du försöker installera Älskarinna 1.1 före du avinstallerar Hustru 1.0, kommer Hustru 1.0 att ta bort alla dina HogiaEkonomifiler innan hon avinstallerar sig själv. Älskarinna 1.1 vägrar då låta sig installeras på grund av brist på resurser.
För att undvika ovan nämnda bugg, försök att installera Älskarinna 1.1 på ett helt annat system och kör aldrig några som helst filöverföringar eller nätverksförbindelser. Undvik också liknande shareware program som t ex Engångsligg 2.1 som kan innehålla virus som påverkar Hustru 1.0.
:e :e :e :e
Krister </BIRE> Lindholm
http://www.lifestyleshop.nu
webmaster@livsstilsbutik.com
Medlem sedan feb. 20002 218 inlägg
Det är inte natt nu men det var kul ändå :e
Freestyler
http://www.sandstrom.f2s.com/
Des Cornichons Au Chocolat
Finns en om fästman/äkta man också. Speciellt varningen om att uppgradera till äkta man eftersom många tror det är något fel på äkta man när han plötsligt bara sitter och tittar på tv och inte alls är lika aktiv och romantisk som fästman.
Ska se om jag hittar den storyn nånstans.
/Petra
251 ms totalt · 4 externa anrop · v20260731065814-full.86ec41c2
118 ms — deklarationer (db)
114 ms — ändringar (db)
