SiteStat v1.0
PHPur Script - PHP
1 svar · 2 780 visningar · startad av Cactuz
Medlem sedan okt. 2001670 inlägg
SiteStat is an easy way to keep an eye on your visitors. It's written in PHP and uses MySQL as databases.
It has a couple of features:
* Can count unique visitors.
* You can password protect the statistics (index.php).
* Easy choose what days you want to view.
* Language packs.
* Ban IPs and referers so they will not be counted.
* Choose what you want to show in the statistics.
* You can use the same counter on many domains and see which one is most visited.
* You can see what pages are most visited.
* Change colors easy in style.css file.
* Use more counters in the same database with prefix.
* Many options in config.php.
Demo
Ladda ner
Medlem sedan juli 20041 271 inlägg
Ingen av länkarna fungerar... :(
132 ms totalt · 3 externa anrop · v20260731065814-full.25f56b17
