Stackalgoritm
0 svar · 1 076 visningar · startad av sgtpepper
sgtpepperMedlem sedan apr. 20005 524 inlägg
Jag lyckades inte hitta några bra stackfunktioner i PHP3 så jag slängde ihop en egen klass.
I PHP4 finns stackmetoderna push och pop implementerade i Arrays.
Detta är en vanlig LIFO ( Last in, First Out) stack.
 * PsStack
 * Class that implements a standard
 * LIFO stack in PHP.
 * (C) Copyright 1999, 2000 by
 * Pär Svanström (per@svanstrom.nu)
 * The code may be used freely but this
 * note must remain intact if the code
 * is redistributed.
 * [url="http://www.svanstrom.nu"]http://www.svanstrom.nu[/url]
class PsStack
	var $stack;
	var $stackPointer = -1;
	var $maxSize;
	 * CONSTRUCTOR
	 * Initialize the max size of the stack.
	 * Default size is set to 100
	function PsStack( $maxSize = 100 )
		$this->maxSize = $maxSize;
	 * ISEMPTY
	 * Returns TRUE if the stack is empty,
	 * otherwise false.
	function isEmpty()
		return ($this->stackPointer == -1);
	 * ISFULL
	 * Returns TRUE if the stack is full,
	 * otherwise false.
	function isFull()
		return ($this->stackPointer >= $this->maxSize - 1);
	 * MAKEEMPTY
	 * Sets the internal stack pointer to
	 * -1, thereby reseting the stack.
	function MakeEmpty()
		$this->stackPointer = -1;
	 * PUSH
	 * Pushes data onto the stack. Dies
	 * with an error if the stack is full.
	function push( $data )
		if($this->isFull())
			die("Stack overflow!");
			$this->stackPointer++;
			$this->stack[ $this->stackPointer ] = $data;
	 * POP
	 * Pops data from the stack. Dies
	 * with an error if the stack is empty.
	function pop()
		if($this->isEmpty())
			die("Stack is empty!");
			$temp = $this->stack[$this->stackPointer];
			$this->stackPointer--;
			return $temp;
	 * TOP
	 * Peeks at the top data without
	 * removing it. Dies if stack is empty.
	function top()
		if(!$this->isEmpty())
			return $this->stack[$this->stackPointer];
Du kan testa stacken med följande kod:
$myStack = new PsStack(10);
$myStack->push("Ett");
$myStack->push("Två");
$myStack->push("Tre");
$myStack->push("Fyra");
$myStack->push("Fem");
$myStack->push("Sex");
$myStack->push("Sju");
$myStack->push("Åtta");
$myStack->push("Nio");
$myStack->push("Tio");
print $myStack->pop() . "<br>";
Utdatat blir följande:
Tio
Nio
Åtta
Sju
Sex
Fem
Fyra
Tre
Två
Ett
Stack is empty!
Vid fel (stack overflow, stack empty) så dör scriptet med ett felmeddelande.
Om stackens konstruktor ej har något argument (dvs. new PsStack();) så sätts stackens maxstorlek till 100.
1010011010 - The binary number of the beast
[Redigerat av sgtpepper den 02 jul 2000]
Genererad på 507 ms · cache AV · v20260730165559-full.f96bc7eb
