Enkelt script för att få fram hur det gått på börsen idag.
Set objHTTP = Server.CreateObject("Microsoft.XMLHTTP")
objHTTP.Open "GET", "http://www.privataaffarer.se/default_frame.asp", False
objHTTP.Send
strHTML=objHTTP.responseText
Set objHTTP = Nothing
Set objRegExp = New regexp
objRegExp.Global = false
objRegExp.IgnoreCase = true
objRegExp.Pattern = "<font face=""Geneva, Arial, Helvetica"" size=""6"" class=index1><b>.*</b></font>"
Set hittade = objRegExp.Execute(strHTML)
Function red(strText)
strText = replace(strtext,"<font face=""Geneva, Arial, Helvetica"" size=""6"" class=index1><b>"," ")
strText = replace(strtext,"</b></font>"," ")
red = strText
End Function
For each item in hittade
With response
.write("Stockholmsbörsen: ")
.write red(item.value)
End with
Next
objHTTP.Send
objRegExp.Pattern = "<font size=5 face=""Arial,Helvetica""><b>.*</b></font>"
strText = replace(strtext,"<font size=5 face=""Arial,Helvetica""><b><b>"," ")
red = strText
End Function
With response
End with
Next
objHTTP.Send
objRegExp.Pattern = "<td>.*<font size=5 face=""Arial,Helvetica""><b>.*</b></font>"
strText = replace(strtext,"<td><img src=""","<img src=""http://www.privataaffarer.se")
red = strText
End Function
With response
End with
Next
Du har ett litet fel i din du har en <b> för mycket!
objHTTP.Send
strText = Replace(strText, "<font size=5 face=""Arial,Helvetica""><b> ", " ")
strText = Replace(strText, "</b></font>", " ")
red = strText
End Function
With response
End with
Next
objHTTP.Open "GET", "http://www.privataaffarer.se", False
objHTTP.Send
objRegExp.Pattern = "<font class=saxBig>.*</font>"
strText = Replace(strText, "<font class=saxBig>", "")
strText = Replace(strText, "</font>", "")
red = strText
End Function
val = red(item.value)
if instr(val,"-") then val="&#9660; "& val else val="&#9650; "& val
Response.Write("Stockholmsbörsen: " & val)
Next
286 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
