Java - Parameter tag
0 svar · 1 385 visningar · startad av Viktor
ViktorMedlem sedan aug. 20021 752 inlägg
Här är en tag som skriver ut en vald parameter från querystring, session eller page contexten.
package com.vgsoftware.vglib.util;
import javax.servlet.jsp.JspTagException;
import javax.servlet.jsp.tagext.TagSupport;
public class ParamTag extends TagSupport
	public String name=null;
	public String type=null;
	public int doEndTag()
	throws JspTagException
		try
			if(type==null||type.equals("query"))
				pageContext.getOut().print(pageContext.getRequest().getParameter(name));
			else if(type.equals("session"))
				pageContext.getOut().print(pageContext.getSession().getAttribute(name));
			else if(type.equals("page"))
				pageContext.getOut().print(pageContext.getAttribute(name));
		catch(java.io.IOException io)
			throw(new JspTagException(io.getMessage()));
		return(EVAL_PAGE);
	public void setType(String type)
		this.type=type;
	public String getType()
		return(type);
	public void setName(String name)
		this.name=name;
	public String getName()
		return(name);
TDL för taggen,
<?xml version="1.0"?>
<!DOCTYPE taglib PUBLIC	"-//Sun Microsystems, Inc.//DTD JSP Tag Library 1.1//EN"
"http://java.sun.com/j2ee/dtds/web-jsptaglibrary_1_1.dtd">
<taglib>
	<tlibversion>1.0</tlibversion>
	<jspversion>1.1</jspversion>
	<shortname>vglib</shortname>
	<info>
	</info>
	<tag>
		<name>param</name>
		<tagclass>com.vgsoftware.vglib.util.ParamTag</tagclass>
		<info></info>
		<attribute>
			<name>name</name>
			<required>true</required>
			<rtexprvalue>true</rtexprvalue>
		</attribute>
		<attribute>
				Here you can set the type of variable that will be read.
				Default is from the querystring, but ok values here are
				query (querystring)
				session (session object)
				page (page context)
			<name>type</name>
			<required>false</required>
		</attribute>
	</tag>
</taglib>
/Viktor
123 ms — hämta forumlista (db)
