Postfix vägrar leverera brev som sänds från en annan dator än min men som finns på samma nätverk, här är resultatet i maillog när jag försöker skicka ett brev från den datorn
Feb 27 09:27:31 celeron postfix/smtpd[7510]: warning: dict_nis_init: NIS domain name not set - NIS lookups disabled
Feb 27 09:27:31 celeron postfix/smtpd[7510]: connect from dell.xxxxx.com[192.168.0.22]
Feb 27 09:27:33 celeron postfix/smtpd[7510]: 3F533201E: client=dell.xxxxx.com[192.168.0.22]
Feb 27 09:27:58 celeron postfix/smtpd[7510]: warning: 22.0.168.192.relays.osirusoft.com: RBL lookup error: Name service error for name=22.0.168.192.relays.osirusoft.com type=A: Host not found, try again
Feb 27 09:27:59 celeron postfix/smtpd[7510]: 3F533201E: reject: RCPT from dell.xxxxx.com[192.168.0.22]: 554 <XXXXX@telia.com>: Relay access denied; from=<XXXXX@xxxxx.com> to=<XXXXX@telia.com> proto=ESMTP helo=<xxxxx.com>
Feb 27 09:28:03 celeron postfix/smtpd[7510]: lost connection after RCPT from dell.xxxxx.com[192.168.0.22]
Feb 27 09:28:03 celeron postfix/smtpd[7510]: disconnect from dell.xxxxx.com[192.168.0.22]
Såhär ser det ut när jag skickar från min dator och där fungerar det perfekt
Feb 27 09:36:39 celeron postfix/smtpd[7608]: warning: dict_nis_init: NIS domain name not set - NIS lookups disabled
Feb 27 09:36:39 celeron postfix/smtpd[7608]: connect from amd.xxxxx.com[192.168.0.10]
Feb 27 09:36:39 celeron postfix/smtpd[7608]: CE6BB201E: client=amd.xxxxx.com[192.168.0.10]
Feb 27 09:36:39 celeron postfix/cleanup[7610]: CE6BB201E: message-id=<403F0169.6030803@xxxxx.com>
Feb 27 09:36:39 celeron postfix/qmgr[7585]: CE6BB201E: from=<XXXXX@xxxxx.com>, size=550, nrcpt=1 (queue active)
Feb 27 09:36:39 celeron postfix/smtpd[7608]: disconnect from amd.xxxxx.com[192.168.0.10]
Feb 27 09:36:40 celeron postfix/smtp[7619]: CE6BB201E: to=<XXXXX@passagen.se>, relay=mail-gw2.asap-asp.com[195.225.3.18], delay=1, status=sent (250 Ok: queued as D17F1733A)
Här är min postfix config fil
broken_sasl_auth_clients = yes
command_directory = /usr/sbin
config_directory = /etc/postfix
daemon_directory = /usr/libexec/postfix
debug_peer_level = 2
mail_owner = postfix
mailbox_transport = cyrus
mailq_path = /usr/bin/mailq
manpage_directory = /usr/local/share/man
mydestination = xxxxx.com, mysql:/etc/postfix/mysql-mydestination.cf
mydomain = xxxxx.com
myhostname = xxxxx.com
mynetworks = 192.168.0.0/28, 127.0.0.0/8
newaliases_path = /usr/bin/newaliases
queue_directory = /var/spool/postfix
readme_directory = no
sample_directory = /etc/postfix
sender_canonical_maps = mysql:/etc/postfix/mysql-cononical.cf
sendmail_path = /usr/sbin/sendmail
setgid_group = postdrop
smtpd_recipient_restrictions =
permit_mynetworks,
reject_non_fqdn_sender,
reject_non_fqdn_recipient,
reject_rbl_client proxies.blackholes.wirehub.net,
reject_rbl_client dnsbl.njabl.org,
reject_rbl_client query.bondedsender.org,
reject_rbl_client bl.spamcop.net,
reject_rbl_client relays.ordb.org,
reject_rbl_client relays.osirusoft.com,
reject_rbl_client sbl.spamhaus.org,
reject_rbl_client blackholes.mail-abuse.org,
reject_rbl_client dialups.mail-abuse.org,
reject_rbl_client relays.mail-abuse.org,
reject_unauth_destination
smtpd_sasl_auth_enable = yes
smtpd_sasl_local_domain = xxxxx.com
smtpd_sasl_security_options = noanonymous
unknown_local_recipient_reject_code = 450
EDIT: Tydligen så var 192.168.0.0/28 för begränsande så jag fick byta till 192.168.0.0/24 och då gick det bra.
/Viktor
