DMZ?
Nätverk
5 svar · 523 visningar · startad av Perss00n
Medlem sedan nov. 200521 inlägg
Tjo!
Om jag lägger min dator utanför brandväggen genom DMZ och installerar en mjukvaru brandvägg, slipper jag då öppnar portar och sån skit då? Samt kan man köra HideIP Platinum med router? Isf hur ska man bära sig åt för att internet går svin segt när den è på.
Perss00n skrev:
Tjo!
Normalt så tror jag bredbandsroutrarna fungerar så.
Släpper igenom allt till DMZ maskinen.
Vad är HideIP platinum för program ?
När HideIP Platinum är på eller ?
Aaaa, precis. När jag slår på HideIP så blir internet slött... Här kommer en liten beskrivning:
Concerned about Internet privacy? Want to hide your IP address?
Hide IP Platinum is the software you are looking for! Keeping your privacy is simple and easy: the only thing you need to do is open Hide IP Platinum.
Hide IP Platinum it helps you to hide your IP address , making it in this way a very useful software.
Hide IP Platinum will find the proxy server available to you and set it as your proxy server automatically. There is nothing need you to concern. Hide IP Platinum have done everything for you!
Here are some key features of "Hide IP Platinum":
· Hide IP Platinum searches for HIGH anonymous proxy server and makes you complete invisible to any websites you are surfing.
· Protect you from any website that wants to monitor your reading interests and spy upon you through your unique IP address - your ID in the Internet
· Avoid your personal information be used to send you spam and junk emails by many marketers and advertising agencies who having information about your interests and knowing your IP address as well as your email
· Keeping your computer away from hacker attacks by hiding your IP address as well as information about your operation system
· Ability to frequently change IP addresses increases privacy
· Enable and disable Hide IP Platinum as your wish with a single click
· Bypass the restrictions by some owners of Internet resources on users from certain countries or geographical regions
· Post on bulletin boards without displaying your real IP address
· Use with a web based mail service to send anonymous email
· Doesn't like oher services force you to pay a monthly fee for anonymous surfing. For a low one-time price, you can visit whatever web sites without anyone ever finding out
Det är väl inte så konstigt egentligen!? När du kör med HideIP så surfar du genom proxys. Du kommer aldrig kunna surfa fortare än vad proxyns lina klarar av. Du är dessutom inte ensam om att använda den proxyn. Säg att du och ett hundratal till personer sitter och surfar genom samma proxy, då delar ni på proxyns lina. Det säger sig själv att det inte går lika fort då.
Medlem sedan jan. 2004527 inlägg
Haha, ja precis, varför vill du gömma din ip-adress? Olagligheter på gång? Fyfyfy
:p
Peeer: Om det hade vart så jävla självklart så hade jag la inte frågat lr?!!!!! DET trycker jag è ganska självklart men men.
283 ms totalt · 4 externa anrop · v20260731065814-full.86ec41c2
127 ms — deklarationer (db)
153 ms — hämta tråd, inlägg och bilagor (db)
127 ms — ändringar (db)
