Masken Lentin
Datasäkerhet
0 svar · 176 visningar · startad av webtomten
Medlem sedan apr. 20003 424 inlägg
Kommer som Sweet.scr eller best-friend.scr till din mail. Finns säkert som andra namn oxå men det är dessa 2 jag råkat ut för.
Hi,
Check the attached screensaver..
eller
Hi,
Its quite obvious that in our life we have numerous friends
but.. BUT Best Friend can only be ONE.. right {BR>so can you decide who is your best friend {BR>i guess not.. cause mostly you will find that your best friend
wont care about u like somebody else..
anyway i found one way to find who is my best friend..
check it..
just check the attached screensaver.. answer some questions
in it and also ask your best friend to answer the questions..
..then you will know more about him..
120 ms — deklarationer (db)
118 ms — ändringar (db)
