PrettyPark worm
Datasäkerhet
1 svar · 415 visningar · startad av stoffe-2k
Summary
The PrettyPark worm spreads in a manner similar to the Melissa worm. It also reveals the victim's passwords on a number of IRC channels. This intrusion detection is triggered on IRC connection attempts containing parameters unique to the PrettyPark worm.
Ok, det är jag med på !
Details
If you see this attack, your system may be compromised.
OK, jag får upp varning,
Check the identify of the intruder. If your own system is indicated as the intruder, then you almost certainly have been compromised.
ja det är det! VA!? skulle jag allså ha viruset på MIN dator?
You should use an anti-virus software program to rid your system of this Worm.
Jo, men jag kör jhu Norton 2001 och givetvis uppdaterar jag min virusdatabas varje natt...
If someone else is indicated as the intruder, then you are probably being scanned by another instance of the worm. In this case, you have not been compromised.
hum, hur gör man nu då ?
MVH - C
"Mina mappar är slut, kan ni sälja mig några nya...?"
- Förvirrad Mac-kund
[Redigerat av stoffe-2k den 16 mar 2001]
Medlem sedan dec. 20003 083 inlägg
Kör ett annat system :e
"...the number of UNIX installations has grown to 10, with more expected..."
- Dennis Ritchie and Ken Thompson, June 1972
263 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
123 ms — deklarationer (db)
125 ms — ändringar (db)
