Outpost Firewall Pro: Mycket varningar!
Datasäkerhet
4 svar · 528 visningar · startad av Sjodahl
Installerat Outpost, men tycker jag får ovanligt mycket varningar med mera... visar er hur loggen kan se ut tex: (kolla tiderna)
11:35:14 n/a IN REFUSED UDP 219.140.73.96 16216 Packet to closed port
11:35:14 n/a IN REFUSED UDP 221.136.98.169 33299 Packet to closed port
11:35:14 n/a IN REFUSED UDP 68.6.236.252 46101 Packet to closed port
11:35:14 n/a IN REFUSED UDP 221.233.26.33 10330 Packet to closed port
11:35:13 n/a IN REFUSED UDP 71.236.146.246 60095 Packet to closed port
11:35:12 n/a IN REFUSED UDP 60.16.69.244 7166 Packet to closed port
11:35:11 n/a IN REFUSED UDP 211.149.211.159 7316 Packet to closed port
11:35:10 n/a IN REFUSED UDP 221.222.147.53 14732 Packet to closed port
11:35:09 n/a IN REFUSED UDP 211.76.254.21 21470 Packet to closed port
11:35:09 n/a IN REFUSED UDP 70.124.213.8 32459 Packet to closed port
11:35:08 n/a IN REFUSED UDP 218.90.149.241 7997 Packet to closed port
11:35:08 n/a IN REFUSED UDP 81.6.248.73 38536 Packet to closed port
11:35:06 n/a IN REFUSED UDP 222.38.153.45 61560 Packet to closed port
11:35:06 n/a IN REFUSED igmp 10.245.7.73 0 *IP Protocol Rule #1
11:35:04 n/a IN REFUSED UDP 194.249.35.120 10605 Packet to closed port
11:35:04 n/a IN REFUSED UDP 59.117.97.244 24406 Packet to closed port
11:35:03 n/a IN REFUSED UDP 68.56.122.180 12022 Packet to closed port
11:35:03 n/a IN REFUSED UDP 82.47.130.81 16120 Packet to closed port
11:35:03 n/a IN REFUSED UDP 222.90.119.104 25851 Packet to closed port
11:35:02 n/a IN REFUSED UDP 24.59.104.90 32459 Packet to closed port
11:35:01 n/a IN REFUSED UDP 147.10.76.61 8403 Packet to closed port
11:35:01 n/a IN REFUSED UDP 220.173.13.235 50055 Packet to closed port
11:35:00 n/a IN REFUSED UDP 83.165.5.217 22057 Packet to closed port
11:35:00 n/a IN REFUSED UDP 219.149.36.134 11867 Packet to closed port
11:35:00 n/a IN REFUSED UDP 220.191.0.218 1270 Packet to closed port
11:34:59 n/a IN REFUSED UDP 221.222.147.53 14732 Packet to closed port
11:34:59 n/a IN REFUSED UDP 80.202.20.73 50523 Packet to closed port
11:34:59 n/a IN REFUSED UDP 24.254.48.49 32937 Packet to closed port
11:34:59 n/a IN REFUSED UDP 211.142.52.162 9141 Packet to closed port
11:34:58 n/a IN REFUSED UDP 87.126.71.58 13831 Packet to closed port
11:34:58 n/a IN REFUSED UDP 24.86.70.56 32459 Packet to closed port
11:34:58 n/a IN REFUSED UDP 219.232.34.10 27670 Packet to closed port
11:34:57 n/a IN REFUSED UDP 88.9.134.170 22758 Packet to closed port
11:34:57 n/a IN REFUSED UDP 24.121.25.243 32459 Packet to closed port
11:34:57 n/a IN REFUSED UDP 220.176.239.21 27041 Packet to closed port
11:34:56 n/a IN REFUSED UDP 221.214.240.25 13928 Packet to closed port
11:34:56 n/a IN REFUSED UDP 81.202.22.75 8288 Packet to closed port
11:34:56 n/a IN REFUSED UDP 24.89.225.147 40543 Packet to closed port
11:34:56 n/a IN REFUSED UDP 219.134.67.33 12453 Packet to closed port
11:34:55 n/a IN REFUSED UDP 221.237.174.133 11462 Packet to closed port
11:34:55 n/a IN REFUSED UDP 213.91.146.2 17302 Packet to closed port
11:34:54 n/a IN REFUSED UDP 195.70.20.169 28003 Packet to closed port
11:34:54 n/a IN REFUSED UDP 85.49.162.128 11926 Packet to closed port
11:34:54 n/a IN REFUSED UDP 218.72.103.66 21641 Packet to closed port
11:34:54 n/a IN REFUSED UDP 218.249.191.254 48798 Packet to closed port
11:34:53 n/a IN REFUSED UDP 74.12.132.251 16366 Packet to closed port
11:34:52 n/a IN REFUSED UDP 58.49.249.250 1722 Packet to closed port
11:34:52 n/a IN REFUSED UDP 202.86.154.33 27570 Packet to closed port
11:34:51 n/a IN REFUSED UDP 221.218.225.117 25933 Packet to closed port
11:34:50 n/a IN REFUSED UDP 86.140.215.246 20736 Packet to closed port
11:34:50 n/a IN REFUSED UDP 218.64.17.176 45541 Packet to closed port
11:34:49 n/a IN REFUSED UDP 221.200.215.93 63325 Packet to closed port
11:34:48 n/a IN REFUSED UDP 62.215.159.144 63535 Packet to closed port
11:34:48 n/a IN REFUSED UDP 218.87.69.171 36180 Packet to closed port
11:34:48 n/a IN REFUSED UDP 217.209.167.209 27506 Packet to closed port
11:34:47 n/a IN REFUSED UDP 58.244.39.196 9381 Packet to closed port
11:34:47 n/a IN REFUSED UDP 218.212.19.59 17380 Packet to closed port
11:34:47 n/a IN REFUSED UDP 211.144.56.85 15629 Packet to closed port
11:34:46 n/a IN REFUSED UDP 83.148.107.174 14850 Packet to closed port
11:34:45 n/a IN REFUSED UDP 59.117.120.8 21588 Packet to closed port
11:34:45 n/a IN REFUSED UDP 71.247.80.205 50729 Packet to closed port
11:34:43 n/a IN REFUSED UDP 211.97.117.171 38472 Packet to closed port
11:34:42 n/a IN REFUSED UDP 220.160.182.29 3204 Packet to closed port
11:34:42 n/a IN REFUSED UDP 222.51.172.96 50978 Packet to closed port
11:34:41 n/a IN REFUSED UDP 220.112.72.134 1501 Packet to closed port
11:34:41 n/a IN REFUSED UDP 221.219.194.17 20000 Packet to closed port
11:34:40 n/a IN REFUSED UDP 218.2.68.217 1501 Packet to closed port
11:34:39 n/a IN REFUSED UDP 58.252.30.172 63205 Packet to closed port
11:34:39 n/a IN REFUSED UDP 71.198.201.200 60095 Packet to closed port
11:34:38 n/a IN REFUSED UDP 219.77.128.111 19800 Packet to closed port
11:34:38 n/a IN REFUSED UDP 60.22.26.148 21643 Packet to closed port
11:34:37 n/a IN REFUSED UDP 83.227.0.146 17277 Packet to closed port
11:34:36 n/a IN REFUSED UDP 211.143.29.6 12206 Packet to closed port
11:34:36 n/a IN REFUSED UDP 217.164.66.149 15495 Packet to closed port
11:34:35 n/a IN REFUSED UDP 201.13.92.38 26180 Packet to closed port
11:34:35 n/a IN REFUSED UDP 70.22.136.153 50884 Packet to closed port
11:34:35 n/a IN REFUSED UDP 60.176.42.244 1097 Packet to closed port
11:34:35 n/a IN REFUSED UDP 24.87.125.0 6883 Packet to closed port
11:34:35 n/a IN REFUSED UDP 59.42.134.32 36734 Packet to closed port
11:34:35 n/a IN REFUSED UDP 211.161.1.24 8430 Packet to closed port
Kör du DC eller Nåt torent program ?
Ser väl ok ut? Porten är inte öppen hos dig i Outpost och blockeras därför. UDP kan vara vadsomhelst nästan som orsakar trafiken från början och alla dessa maskiner kan ju faktiskt vara infekterade med någon typ av mask eller virus som sedan försöker spridas till din maskin, men det stoppas av Outpost vad jag kan se.
Japp torrent ibland, men just där hade jag inte gjort det, så hade med en fundering om typ det låg kvar lite öppna sessioner även efter jag stängt ner programmet (utorrent)
hmm okej, tänkte väl mest ioch med det var så himmla många och så jädrans ofta borde det vara något annat. Visst får man väl lite skit i loggarna. Men borde väl inte rassla in en 5-6st i sekunden hela tiden.
313 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
125 ms — deklarationer (db)
176 ms — hämta tråd, inlägg och bilagor (db)
135 ms — ändringar (db)
