err1err3
Datorhårdvara
3 svar · 1 086 visningar · startad av Lasse H
En laptop med AMD*2 processor visar bara svartskärm med texten "err1err3" vid uppstart.
Någon som har en aning om vad felet kan vara?
Medlem sedan juni 2009920 inlägg
Kolla hårddisken. Det var iallafall vad google sa till mig när jag sökte på felmeddelandet :)
Boota med Vista recovery CD > välj repair > välj command prompt > osv... ;)
I resolved the Err1Err3 error message by doing the following with my Vista recovery cd. First boot with the recovery disc and select the repair option, then select command prompt and then run the commands in this order:
type chkdsk /r
take note of your Bad Sectors(disk had none)
after this is done type bootrec /fixmbr
then bootrec /fixboot
then bootrec /rebuildbcd
The Err1Err3 message disappeared on reboot and booted straight into windows were I was able then to the a system restore to date well before the system crashed. The message Err1Err3 must mean that your bootloader or boot partition is damaged.
Hope this helps anyone who gets the message Err1Err3.
http://www.technibble.com/forums/showthread.php?t=12047
259 ms totalt · 4 externa anrop · v20260731065814-full.1dc6f849
127 ms — deklarationer (db)
124 ms — ändringar (db)
