varför hittar inte min telefon mitt headset?
Mobiltelefoner
2 svar · 325 visningar · startad av magnusfeldth
Köpte idag blåtandsheadsetet Motorola HS801. Det ska universellt och funka med "blåtandstelefoner från motorola och andra tillverkare"... Men jag kan inte få det att funka på min motorola A1000.... den hittar inte headsetet? Jag har aktiverat blåtand på telefonen och satt på headsetet och därefter gått in på kontrollpanelen - anslutningar - blåtand - enheter och valt lägg till. Då söker den, men den hittar inget... :(
hur göra?
Hittade en supportsajt på motorola, där man valde precis vilken telefon man skulle koppla den till. Nu funkar det! :moose
Så här gjorde man:
motorola skrev:
HS801 to Motorola A1000 Printer-friendly Version
Activate Bluetooth®:
1. Starting with the phone, tap on the "Launcher" icon.
2. Tap on "Control Panel."
3. Tap on the "Connections" tab.
4. Tap on "Bluetooth."
5. If there is a check mark in the box next to "Bluetooth on," proceed to the next step (step 6). If there is no check mark in the box next to "Bluetooth on," tap on the box and a check mark will appear in the box. Then proceed to the next step (step 6).
6. Next to the option "Visible to other devices," tap on "Yes."
7. Tap on the "Devices" tab.
Putting the Headset into Pairing Mode:
8. First turn the headset on by pressing and holding both the Call button and a side button (volume up or volume down button) for more than 2 seconds, until the headset lights up. The headset is on when the light begins flashing a few seconds later. Then press and hold the side button (volume up or volume down button) until the light shines steadily – at least 3 seconds. (Initially, the light will flash a few times before staying lit.) If the light is flashing, or if the light starts flashing anytime during steps 9 and 10, the headset is not in pairing mode, and this step (step 8) needs to be repeated, beginning with the headset powered off.
Select the HS801 Headset:
9. Tap on "Add." The phone will start searching for Bluetooth enabled devices such as your headset.
10. A list of one or more Bluetooth enabled devices will appear on the screen. Tap on "Motorola HS801." Then a screen will appear indicating that pairing is in-process.
11. The next screen will ask for a passkey to be entered. Enter 0000 and tap on "Done." A screen will appear confirming the pairing and the connection. Since the pairing is complete, the light on the headset will be flashing.
Det var efter man satt på headsetet som man skulle göra en grej till som jag hade missat.
267 ms totalt · 4 externa anrop · v20260731065814-full.6fe65c25
134 ms — deklarationer (db)
133 ms — ändringar (db)
