Mac OS X: Promise without the polish
Datorhårdvara
10 svar · 444 visningar · startad av Reefer
Medlem sedan dec. 20003 083 inlägg
http://www.zdnet.com/zdnn/stories/news/0,4586,2691847,00.html?chkpt=zdhpnews01
Utdrag ur artikeln;
Sources familiar with the first ground-up rewrite of Apple Computer's (Nasdaq: AAPL) operating system since the Mac's debut in 1984 said the initial version will not be able to play or write DVDs. Other gaps, such as sleep problems with Mac laptops, also will limit the new OS' usefulness to certain users--although none rise to the level of aggravation that the lack of DVD support is likely to cause.
Although it is common for new operating systems to have glitches, such as those that hampered Windows 95 and Mac's OS 7, some analysts were troubled by some of the problems with OS X.
"It's clearly not a positive," said David Bailey, senior analyst at Gerard Klauer Mattison. "We didn't expect huge acceptance of the software initially, not until Mac OS X-native applications are available in the summer--but then, the lack of DVD playback takes away functionality."
An Apple representative declined to comment on any aspect of the development of OS X.
Unix-klon med Aqua interface = snyggt skal men/med ingen/inga av dom funktioner som Jobs skröt med...
MUHAHAHAHAHAHHA!!!....osv. §e
Tar väl ytterligare ett par år för Jobs & co att addera dom till systemet... ;)
"Develop for it? I'll piss on it."
Microsoft CEO Bill Gates, about developing
applications for Steve Jobs' NeXT Computers -
which led to the demise of NeXT in 1993.
Öh, så Apple får tummen ner därför att ett OS som inte är släpp ännu inte hinner få DVD-stödet (dvs att kunna bränna sina egna DVD-skivor... att spela DVD-skivor funkar redan i betorna)??
Nog har opponenternat lite att klaga på i såfall.
/Petra
If you see someone without a smile, give them yours.
Ooopps, dont look now Petra, men där avslöjade du att du inte har läst artikeln, hade du gjort det så hade du vetat detta;
Waiting for Puma
Among the other problems with the March release, sources said, is that it won't take full advantage of multiprocessing systems or new video accelerators, such as Nvidia's recently announced GeForce 3 or ATI's Radeon. People who have systems containing these new graphics cards may not see a speed-up of 3D or 2D graphics until support is introduced with Puma.
Owners of portable Macs also may experience some problems, including power-management issues affecting the OS' ability to awaken and go to sleep. Intermittent bugs affecting the sleep cycle may not be resolved by the time Cheetah reaches the so-called golden master, and the development team has not fully tested its stability on the newest Apple hardware, including the PowerBook G4 Titanium.
The Mac OS X development team also has flagged a variety of bugs, some causing system hangs or freezes, in the Setup Assistant application, which helps people configure their systems. While the glitches "may affect user experience," sources said, the team has deferred fixes to later versions.
Finally, sources noted diminished performance when people run applications that have not been written specifically for OS X. Although some operations, such as opening windows, perform faster in the so-called Classic mode, most applications will run more slowly, sources said.
Ben Long, a media specialist and writer who has covered multiple operating systems, said the missing features in Mac OS X 1.0 surprised him.
"I don't remember another transition leaving out functionality--not in the move to System 7, not in the move to PowerPC," the predecessor to today's G3 and G4 machines, he said.
Though the lack of DVD may be a problem "mostly for portable users" who use their PowerBooks as portable players, Long said the speed hit in Mac OS X's Classic environment would most likely be the most troubling.
"Like most people, I'm not going to be installing Mac OS X until the high-performance applications are Carbonized," he said, referring to the process of tailoring the software to run optimally on the OS.
Long noted that print professionals upgrade entire systems to shave seconds off frequently used operations such as Photoshop filters; an operational slowdown of even 10 percent, he said, would seriously affect productivity.
"Most people who install Mac OS X 1.0 will probably be spending as much, if not more, time booted into Mac OS 9," he said.
Alltså, taskigt grafikstöd, taskigt DVD-stöd, brist på apps skrivna för MacOS X, slö systemperformance, taskigt stöd för bärbara (sleep-mode), obefintligt SMP-stöd och allmänt buggigt...etc etc, a well, sure they fixed it to the "Puma"- release...dvs någon gång nästa år ;)
[Redigerat av Reefer den 02 mar 2001]
Samtidigt är jag väldigt tveksam till några som recenserar ett program som inte är släppt ännu. Apple släpper nya developerkopior varje vecka (ibland oftare) så att det inte funkar med vissa delar är inte förvånande alls.
Somliga säger ju att Windows 2000 inte är något att ha förrän man har installerat minst ett Service Pack... sedär.
Man kanske inte ska sälja skinnet innan björnen är skjuten.
/Petra
Medlem sedan jan. 2000229 inlägg
Reefer, har jag rätt om jag antar att du är en trogen MS-diggare? Tar jag fel där ber jag om förlåtelse.
Att lägga energi på att klaga på Mac OS X vid denna tidpunkt gör att jag undrar om MS och deras anhängare börjar känna att den 23 mars närmar sig och lite FUD skulle passa bra i dessa tider.
Jag kör Mac OS X själv och är helt nöjd. DVD-stödet kommer tämligen snabbt, jag dömer inte ut systemet p.g.a det. Till hösten, då jag tänker gå över helt till OS X fungerar DVD-skivorna normalt. Apple har ju DVD-R i sin G4/733 och det kan köpas som extern enhet till andra G4:or (och iMacar med FW). Därför kommer DVD-stödet att introduceras snabbt. Kom också ihåg att det är några veckor till lanseringen, det finns tid för Apple att lägga till DVD-stödet.
Klagande på Apples produkter från Windows-håll är annars vanligt. MS tycker ju att det är ett bra sätt att marknadsföra sig.
Intresserar sig för debatter om olika saker
Petra
Ja...sedär vaddå? jag säger att det inte är något att ha förrens efter 4 service packs...
Vilket är precis vad Apple gör i det här fallet.
Ilyushin
Du tar grovt fel men förlåtelsen är godtagen :e
Jag gläds åt alla Macintosh-användare som äntligen kommer att få ett OS som bygger på världens bästa concept och design för hur ett operativsystem ska vara uppbyggt och fungera, namely UNIX,
efter hur många år som helst med ett OS som borde gått i graven i början av 90-talet, kan bara hoppas att Apple inte förstört alltför mycket av grundiden med ett UNIX system. :e
Men varför skulle 92% (=Windows) av datoranvändarna vara rädda för något som kommer 3% av dito tillgodo?
Nu var du ju en hel del annat också som kommer att fattas i den skarpa releasen, och tre veckor är ingen tid alls i det här sammanhanget.
Se mitt första svar ovan, dessutom är hata-MS, ett kännetecken för dom flesta Mac-användare.
Medlem sedan apr. 20002 882 inlägg
Jasså? Har inte hittat nånstans i dina inlägg nåt från Apple om att pusha för Max OS X, däremot en massa kritisk text om en beta...
Vet du nåt som inte vi vet? ;)
To be or not to be - that's not a question!
Q
Här förstår jag inte ett dugg vad du menar...förklara! :)
Läs artikeln som länken i mitt första inlägg längst upp i den här tråden refererar till ;)
*/tror att Q har blivit lite "Mac-infested" från sitt arbete :e
Hjälp vad långa meningar du skriver. Får ju klippa mitt i en mening.. :)
Själv hoppas jag att de inte gjort allt för stora ändringar jämfört med gamla MacOS. Gränssnittet (säger man så?) i gamla MacOS tycker jag är suveränt! Och om Unix är så bra som Reefer och många andra säger så borde det här operativsystemet bli riktigt bra! :)
/Erik
Reefer: Jag menar så här:
Att sälja skinnet innan björnen är skjuten innebär ju att en viss marknadsföring krävs/har förekommit, men i den artikel du hänvisar till hittar jag inte ett enda officiellt ord från Apple. Nu skummade jag igenom texten, men den återkommande frasen är "sources said" och liknande, dvs anonyma källor som kan dra till med vad som helst eftersom de är just anonyma.
Nu inte sagt att de har det, men jag har alltså inte hittat några belägg för att Apple ska ha sagt "Skaffa Mac OS X så löser sig alla dina problem", utan mest fraser från dessa källor.
Alltså undrar jag om du har några andra länkar på lager där Apple lägger ut texten! ;)
Vad gäller den eventuella "Mac-smitta" jag har fått på sistone så förnekas detta vänligt men bestämt! ;)
Har aldrig varit speciellt intresserad av ren pajkastning mellan OS, men en nyanserad diskussion om för- och nackdelar tackar jag däremot aldrig nej till!
Jag har använt Windows ända sen jag lyfte ögonen från min C-64 och högstadiets Compis och nu har jag äntligen fått möjlighet att lära mig MacOS ordentligt. Ju bredare kunskap desto bättre! :)
Gränsnittet i den skarpa Mac OS X-versionen är uppbyggt på samma sätt som Mac OS Classic (9). Däremot är det ju Aqua, men när man arbetar med det fungerar det som i det vanliga systemet. Det betyder att man slipper en påfrestande omställning, även om det finns mycket nytt.
Mac OS X bygger på BSD och Mach. Apple har inte "förstört Unix" med systemet. Eftersom marknadsföringen inte startar förrän till sommaren misstänker jag att man släpper en för-release 1.0 och sedan en 1.1 där DVD-stöd m.m finns. Apple har ju intresse av det eftersom många G4:or har DVD (även diverse G3:or). Den senaste G4/733 har ju DVD-R/CD-RW-enhet (SuperDrive) som naturligtvis måste stödjas. Därför kommer den optimala OS X-versionen vara den uppdaterade 1.1:an som lär komma till sommaren (förinstallerat på maskiner och till försäljning, samt som uppgradering för de som tar tåget nu i mars).
274 ms totalt · 4 externa anrop · v20260731065814-full.6fe65c25
135 ms — deklarationer (db)
130 ms — ändringar (db)
