BearShare
2 svar · 167 visningar · startad av Insider
Har nyss installerat BearShare.
När jag sedan ska starta det står varningstexten: 'Det gick inte att hitta DLL-filen WS2_32.DLL'
Vad gör jag?
Sök upp den filen på nätet och lägg in den bland dom andra dll'erna. ;)
mottMedlem sedan juni 20001 356 inlägg
Q: Why am I getting an error about WS2_32.DLL?
A: Early versions of Windows 95 don't have this WinSock 32 file. You can get the file from Microsoft. It is possible that you may have windows installed in a different directory than is expected or that you simply have a different location for your DLL files. One way to fix this problem is to find those DLL files that are needed and copy them to the C:\Windows\System directory. If your version of windows was not installed in a typical manner you may need to create this directory. If this still doesn't fix your problem, you may need to find a more up-to-date version of the DLL file.
Daniel Mott
________________
War Is Peace. Ignorance Is Strength. Freedom Is Slavery.
1984, George Orwell
[: E-posta gärna. :]
