VPNetMon
1 svar · 1 133 visningar · startad av septor
septorMedlem sedan nov. 2003208 inlägg
Vill bara tipsa om ett grymt bra program för att övervaka VPN, jag kör detta med Dold.se och det fungerar perfekt. :)
Beskrivning:
*A very lightweight utility for monitoring and securing the VPN connection
VPNetMon prevents unsecured connections after your VPN connection went down. It simply closes specified applications when the VPN connection is down (for example SecureIX or Relakks Service).
If soft closing of the applications is not possible it will kill the applications the hard way. So make sure to deselect any additional questions of your applications like "do you really want to quit?" when it's shutting down.
You will find VPNetMon very useful once you've tried it!*
Hämta programmet här!
Yup, ska testas, danke ;)
134 ms totalt · 3 externa anrop · v20260731065814-full.29ac60f6
