Hejsan,
Jag har precis formaterat min dator och får inte grafikkortet att lira. Jag vet att grafikkortet suger men med det installerat så hackar det iaf inte när man scrollar på hemsidor.
Jag har en DELL dator och har provat att installera med alla drivrutiner som följer med. Men installationen hinner bara precis börja innan den stängs av igen.
Någon som har tips på vad jag kan göra?
QuidMedlem sedan juni 20006 025 inlägg Jag har provat att installera de drivisarna men installationen säger bara.
"The NVIDIA Setup program could not locate any drivers that are compatible with your current hardware. Setup will now exit."
Men enligt DELL ska det ju sitta ett sånt kort i, "256MB NVIDIA GEFORCE 7300LE TURBOCACHE G".
SjodahlMedlem sedan maj 20033 218 inlägg Vad var det för DELL modell du hade ?
Det är en Dell Dimension 9150.
SjodahlMedlem sedan maj 20033 218 inlägg LoLoMedlem sedan feb. 20072 750 inlägg
Här är svar på den error du får.
When I want to upgrade my driver I receive the error:"nvidia setup program could not locate any drivers that are compatible with your current hardware".What should I do?
nVidia drivers are based on a system called Unified Driver Architecture (UDA) which means all nVidia card drivers are using one driver. However for some reasons, they just remove the support for installing those drivers for some cards.
Those restrictions were unlocked and also were fixed some problems and tweaking the drivers for the best experience with your laptop/desktop and nVidia graphics card. This means ALL nVidia based graphics cards can use ANY of the drivers after using a 'modification'.
If you try to install any of these drivers without modification , you will most likely get this error:
"nVidia setup program could not locate any drivers that are compatible with your current hardware. Setup will now exit."
All drivers come with an "Installation INF(ormation) file". This tells the installer how to install the driver.The INF has the instructions to what files to copy and where.It will also setup settings to install with.
The INF also has a list of products that it will install for.nVidia provides UDA (Unified Driver Architecture) where the driver should work for all their released GPUs.So the driver itself will support ALL GPUs, but the INF the driver comes with will only support a selected set of GPU.
This is because of the restrictions of driver itself. To solve this issue and install the driver as it should be for your graphics card, you have to use 'Modded INF'.
For instructions go here: http://www.laptopvideo2go.com/forum/index.php?showtopic=9243
http://www.helpero.com/Questions-and-answers/Computers/Drivers/When-I-want-to-upgrade-my-driver-I-receive-the-error-nvidia-setup-program-could-not-locate-any-drivers-that-are-compatible-with-your-current-hardware-What-should-I-do_10355.html
Där finns lösning för ditt problem iaf, om du inte kan engelska är här fusköversättningar:
http://www.worldlingo.com/S1790.5/translation?wl_srclang=en&wl_trglang=sv&wl_url=http://www.helpero.com/Questions-and-answers/Computers/Drivers/When-I-want-to-upgrade-my-driver-I-receive-the-error-nvidia-setup-program-could-not-locate-any-drivers-that-are-compatible-with-your-current-hardware-What-should-I-do_10355.html
Men denna länk är viktigast att följa
har du problem med översättningen gå till: http://www.worldlingo.com/
Hoppas det hjälper dig nu. ;)
