Hej
Min fråga rör miranda. När jag bytte till version 0,4 så upptäckte jag till mitt förtret att programet inte kopplar upp icq och msn automatiskt vid start. Detta måste man istället göra manuellt. Går detta att ändra på?
19 svar · 1 211 visningar · startad av stork
Hej
Startuppstatus pluginet
eller Always online
Här e min conf på miranda
CPU: AMD Athlon(tm) XP 3200+ [x86 Family 6 Model 10 Stepping 0]
Operating System: Microsoft Windows XP [version: 5.1.2600 Service Pack 2]
Installed RAM: 1024 MBytes
Free disk space on Miranda partition: 16904 MBytes
Miranda path: C:\Program Files\Miranda IM
Miranda IM version: 0.4.3 alpha build #52
Build time: 20:19:16 on 25 April 2006
Profile size: 8,102.48 KBytes
Profile creation date: 21 Dec 2005 at 03:36:00
Nightly: Yes
Unicode core: NoActive Plugins (26):
alwaysonline.dll v.0.3.5.8 [17 Oct 2003] - AlwaysOnline
changeinfo.dll v.0.3.2.0 [28 Jun 2005] - Change User Details
clist_modern.dll v.0.4.2.28 [25 Apr 2006] - Modern Contact List
ContactInfoExport.dll v.0.0.0.1 [14 Apr 2003] - ContactInfo Export
CopyIP.dll v.0.0.0.3 [16 Feb 2002] - Copy IP
dbx_3x.dll v.0.5.1.0 [25 Apr 2006] - Miranda database driver
historysweeper.dll v.0.1.1.3 [28 Jun 2003] - History Sweeper
historyw.dll v.0.1.0.1 [04 Sep 2005] - History/C++ [Unicode] viewer
ICQ.dll v.0.3.6.16 [25 Apr 2006] - IcqOscarJ Protocol
loadavatars.dll v.0.0.1.21 [06 Apr 2006] - Avatar service
msn.dll v.0.4.3.0 [25 Apr 2006] - MSN Protocol
msnip.dll v.0.4.3.0 [31 Jan 2006] - MSN Protocol
nudge.dll v.0.0.1.7 [03 Apr 2006] - Nudge
osd.dll v.0.1.1.4 [17 Jan 2005] - OSD Plugin
png2dib.dll v.0.1.3.0 [25 Apr 2006] - PNG images processor
reconnect.dll v.0.0.1.5 [26 Sep 2002] - ReConnect
rss.dll v.0.0.3.9 [07 Feb 2006] - RSSNews
SecureIM.dll v.1.0.4.4 [26 Aug 2003] - SecureIM 1.0.4.4
seenplugin.dll v.5.0.1.1 [23 Sep 2003] - Last seen plugin
smileyadd.dll v.0.1.12.3 [11 Apr 2006] - SmileyAdd
Snapping_windows.dll v.0.0.1.9 [30 Sep 2005] - Snapping windows
StartupStatus.dll v.0.0.3.1 [26 Jul 2005] - StartupStatus
tabsrmm.dll v.0.9.9.200 [25 Apr 2006] - tabSRMsg
UpTime.dll v.0.1.0.0 [31 May 2002] - Shows Windows UpTime
versioninfo.dll v.1.0.1.19 [23 Mar 2006] - Version Information
YAWN.dll v.1.0.1.0 [16 Feb 2003] - Yet Another Winamp Notifier
Jag lyckades inte riktigt med startup pluginet. vad exakt är det jag ska kryssa i för rutor.
Är det fler som har det här problemet i miranda?
med vilket startupp plugin ?
du kan ju ange det i genvängen också ""C:\Program Files\Miranda IM\miranda32.exe" /ICQ=online /MSN=online /MSNIP=online"
så har ja för min så startar den upp med alla mina protokoll online
Hej
Mayday, jag lyckades faktiskt ändra i genvägen så att det fungerade perfekt. Men nu har jag formaterat min dator igen och jag lyckas helt plötsligt inte få till det.
så här är min genvägen
"C:\Program\Miranda IM\miranda32.exe" /ICQ=online /MSN=online /MSNIP=online"
Vad gör jag för fel
fin plugins annars
Always online samt Strartupp status
Free disk space on Miranda partition: 49329 MBytes
Miranda IM version: 0.6 alpha build #14 Unicode
Build time: 10:30:58 on 16 October 2006
Profile size: 2,240.00 KBytes
Profile creation date: 12 Sep 2006 at 03:41:33
Language pack: No language pack installed
Nightly: Yes
Unicode core: YesActive Plugins (21):
avatarhist.dll v.0.0.1.0 [30 Jun 2006] - Avatar History
chat.dll v.0.6.1.1 [16 Oct 2006] - Chat (Unicode)
clist_modern.dll v.0.4.3.59 [16 Oct 2006] - Modern Contact List (UNICODE)
ContactInfoExport.dll v.0.0.0.1 [15 Apr 2003] - ContactInfo Export
dbx_mmap.dll v.0.6.2.6 [16 Oct 2006] - Miranda mmap database driver
help.dll v.0.1.2.2 [16 Oct 2006] - Help
ICQ.dll v.0.3.8.4 [16 Oct 2006] - IcqOscarJ Protocol (Unicode)
loadavatars.dll v.0.0.2.11 [16 Oct 2006] - Avatar service (Unicode)
msn.dll v.0.6.0.1 [16 Oct 2006] - MSN Protocol (Unicode)
msnip.dll v.0.6.0.1 [16 Oct 2006] - MSN Protocol (Unicode)
newAvatarNotify.dll v.0.0.1.1 [27 Jun 2006] - New Avatar Notify
nudge.dll v.0.0.1.11 [08 Aug 2006] - Nudge
png2dib.dll v.0.1.3.1 [16 Oct 2006] - PNG images processor
rss.dll v.0.0.3.12 [22 Aug 2006] - RSSNews
smileyaddw.dll v.0.1.12.7 [10 Jun 2006] - SmileyAdd Unicode
tabsrmm.dll v.1.1.0.11 [16 Oct 2006] - tabSRMsgW (unicode)
updater.dll v.0.4.11.0 [07 Sep 2006] - Updater
versioninfo.dll v.1.3.0.4 [16 Oct 2006] - Version Information
Jag lyckas inte hitta någon av protokollen på mirandas hemsida
Hej
Får jag fråga om ni andra som använder miranda har samma problem. Jag har ju testat de senaste versionerna och där kopplar det inte upp sig automatiskt för min del i alla fall.
stork skrev:
Hej
Vad gör jag för fel
Om du fortfarande har det likadant som det står ovan behöver du ett " till i början, där ska det vara dubbla.
Det går väll inte att ha dubbla citattecken i en genväg. Jag lyckades då inte lägga till ett. Det stod att det inte gick.
Kolla om du inte har valt "Lock(Lås)" på de olika protokollen.
Klicka på de längst ner och är det låst så står det "(locked)" efter namnet på protokollet. Då ansluter den ej automatiskt vid start.
Grayhound, jag ser inte att det står locked någonstans. Jag förde musen över protokolliconen för icq och msn längst ner i fönstret och såg ingenting.
ta bort det mittersta citationstecknet.
Det fungerade inte heller att ta bort citattecknet i mitten
vilken ver kör du ?
samt vilken build?
Här e min
Free disk space on Miranda partition: 39603 MBytes
Miranda IM version: 0.6 alpha build #16 Unicode
Build time: 22:09:00 on 29 October 2006
Profile size: 2,368.00 KBytes
Nightly: Yes
chat.dll v.0.6.1.3 [30 Oct 2006] - Chat (Unicode)
clist_modern.dll v.0.4.3.60 [30 Oct 2006] - Modern Contact List (UNICODE)
dbx_mmap.dll v.0.6.2.6 [29 Oct 2006] - Miranda mmap database driver
help.dll v.0.1.2.2 [30 Oct 2006] - Help
ICQ.dll v.0.3.8.5 [30 Oct 2006] - IcqOscarJ Protocol (Unicode)
loadavatars.dll v.0.0.2.11 [30 Oct 2006] - Avatar service (Unicode)
msn.dll v.0.6.0.1 [30 Oct 2006] - MSN Protocol (Unicode)
msnip.dll v.0.6.0.1 [30 Oct 2006] - MSN Protocol (Unicode)
nudge.dll v.0.0.1.12 [20 Oct 2006] - Nudge
png2dib.dll v.0.1.3.1 [29 Oct 2006] - PNG images processor
rss.dll v.0.0.3.13 [21 Oct 2006] - RSSNews
smileyaddw.dll v.0.1.12.8 [03 Nov 2006] - SmileyAdd Unicode
tabsrmm.dll v.1.1.0.11 [30 Oct 2006] - tabSRMsgW (unicode)
updater.dll v.0.4.12.0 [31 Oct 2006] - Updater
versioninfo.dll v.1.3.1.0 [02 Nov 2006] - Version Information
startas med "C:\Program Files\Miranda IM\miranda32.exe" inget mer går online direkt på mina protokoll ant tack vare Alwaysonline pluginet som ja posta lite längre upp
jag kör version 0,51 men har givetvis testat ett par olika versioner på ett par olika datorer till och med, problemet är detsamma.
vad gäller den här builden så vet jag inte hur man får fram den.
klicka på about
Åh mayday
jag får ju inte fram någon sådan där fin build som du får när jag trycker på about.
vad 17 gör jag för fel?
ladda hem den senaste är ju ett steg i rätt riktning
