Jag har nyligen formaterat min hårddisk och nu har jag stora problem med "GD library". :l
Det verkar som att min php.ini inte kan "hitta" den .dll filen av någon underlig anledning.
(Felet uppstod när jag testade att köra "Coppermine Photo Gallery".)
Innan jag formaterade om datorn, fungerade "GD" kanon.
Har även dubbelkollat så att php_gd2.dll ligger under "C:\www\php\extensions".
Såhär ser det ut i min php.ini
; Dynamic Extensions ;
; If you wish to have an extension loaded automatically, use the following
; syntax:
; extension=modulename.extension
; For example, on Windows:
; extension=msql.dll
; ... or under UNIX:
; extension=msql.so
; Note that it should be the name of the module only; no directory information
; needs to go here. Specify the location of the extension with the
; extension_dir directive above.
;Windows Extensions
;Note that MySQL and ODBC support is now built in, so no dll is needed for it.
;extension=php_bz2.dll
;extension=php_cpdf.dll
;extension=php_crack.dll
;extension=php_curl.dll
;extension=php_db.dll
;extension=php_dba.dll
;extension=php_dbase.dll
;extension=php_dbx.dll
;extension=php_domxml.dll
;extension=php_exif.dll
;extension=php_fdf.dll
;extension=php_filepro.dll
extension=php_gd2.dll
;extension=php_gettext.dll
;extension=php_hyperwave.dll
;extension=php_iconv.dll
;extension=php_ifx.dll
;extension=php_iisfunc.dll
;extension=php_imap.dll
;extension=php_interbase.dll
;extension=php_java.dll
;extension=php_ldap.dll
;extension=php_mbstring.dll
;extension=php_mcrypt.dll
;extension=php_mhash.dll
;extension=php_mime_magic.dll
;extension=php_ming.dll
;extension=php_mssql.dll
;extension=php_msql.dll
;extension=php_oci8.dll
;extension=php_openssl.dll
;extension=php_oracle.dll
;extension=php_pdf.dll
;extension=php_pgsql.dll
;extension=php_printer.dll
;extension=php_shmop.dll
;extension=php_snmp.dll
;extension=php_sockets.dll
;extension=php_sybase_ct.dll
;extension=php_w32api.dll
;extension=php_xmlrpc.dll
;extension=php_xslt.dll
;extension=php_yaz.dll
;extension=php_zip.dll
;extension=php_pspell.dll
Kör php, apache2, mysql och phpmyadmin under Windows Xp Pro precis som tidigare.
Vad är det som är fel? :x
