samba startar... inte... ?
11 svar · 474 visningar · startad av nanne
nanneMedlem sedan dec. 19991 749 inlägg
När jag startar samba på min redhat 7.1 maskin så säjer den att allt går bra. Men när jag kör smb -status så säjer den att allt är nere och det går inte att komma åt maskinen... Hur ska jag fixa detta?
nizzyMedlem sedan juli 2001183 inlägg
posta din smb.conf
[global]
# workgroup = NT-Domain-Name or Workgroup-Name
workgroup = HYBRIS
# server string is the equivalent of the NT Description field
server string = Samba Server
# This option is important for security. It allows you to restrict
# connections to machines which are on your local network. The
# following example restricts access to two C class networks and
# the "loopback" interface. For more examples of the syntax see
# the smb.conf man page
hosts allow = 192.168.1. 192.168.2. 127.
# if you want to automatically load your printer list rather
# than setting them up individually then you'll need this
printcap name = /etc/printcap
load printers = yes
# It should not be necessary to spell out the print system type unless
# yours is non-standard. Currently supported print systems include:
# bsd, sysv, plp, lprng, aix, hpux, qnx
printing = lprng
# Uncomment this if you want a guest account, you must add this to /etc/passwd
# otherwise the user "nobody" is used
; guest account = pcguest
# this tells Samba to use a separate log file for each machine
# that connects
log file = /var/log/samba/%m.log
# Put a capping on the size of the log files (in Kb).
max log size = 0
# Security mode. Most people will want user level security. See
# security_level.txt for details.
security = user
# Use password server option only with security = server or
# security = domain
; password server = <NT-Server-Name>
# Password Level allows matching of _n_ characters of the password for
# all combinations of upper and lower case.
; password level = 8
; username level = 8
# You may wish to use password encryption. Please read
# ENCRYPTION.txt, Win95.txt and WinNT.txt in the Samba documentation.
# Do not enable this option unless you have read those documents
; encrypt passwords = yes
; smb passwd file = /etc/samba/smbpasswd
# The following is needed to keep smbclient from spouting spurious errors
# when Samba is built with support for SSL.
ssl CA certFile = /usr/share/ssl/certs/ca-bundle.crt
# The following are needed to allow password changing from Windows to
# update the Linux sytsem password also.
# NOTE: Use these with 'encrypt passwords' and 'smb passwd file' above.
# NOTE2: You do NOT need these to allow workstations to change only
# the encrypted SMB passwords. They allow the Unix password
# to be kept in sync with the SMB password.
; unix password sync = Yes
; passwd program = /usr/bin/passwd %u
; passwd chat = *New*UNIX*password* %n\n *ReType*new*UNIX*password* %n\n *passwd:*all*authentication*tokens*updated*successfully*
# Unix users can map to different SMB User names
; username map = /etc/samba/smbusers
# Using the following line enables you to customise your configuration
# on a per machine basis. The %m gets replaced with the netbios name
# of the machine that is connecting
; include = /etc/samba/smb.conf.%m
# Most people will find that this option gives better performance.
# See speed.txt and the manual pages for details
socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
# Configure Samba to use multiple interfaces
# If you have multiple network interfaces then you must list them
# here. See the man page for details.
; interfaces = 192.168.12.2/24 192.168.13.2/24
# Configure remote browse list synchronisation here
# request announcement to, or browse list sync from:
# a specific host or from / to a whole subnet (see below)
; remote browse sync = 192.168.3.25 192.168.5.255
# Cause this host to announce itself to local subnets here
; remote announce = 192.168.1.255 192.168.2.44
# Browser Control Options:
# set local master to no if you don't want Samba to become a master
# browser on your network. Otherwise the normal election rules apply
; local master = no
# OS Level determines the precedence of this server in master browser
# elections. The default value should be reasonable
; os level = 33
# Domain Master specifies Samba to be the Domain Master Browser. This
# allows Samba to collate browse lists between subnets. Don't use this
# if you already have a Windows NT domain controller doing this job
; domain master = yes
# Preferred Master causes Samba to force a local browser election on startup
# and gives it a slightly higher chance of winning the election
; preferred master = yes
# Enable this if you want Samba to be a domain logon server for
# Windows95 workstations.
; domain logons = yes
# if you enable domain logons then you may want a per-machine or
# per user logon script
# run a specific logon batch file per workstation (machine)
; logon script = %m.bat
# run a specific logon batch file per username
; logon script = %U.bat
# All NetBIOS names must be resolved to IP Addresses
# 'Name Resolve Order' allows the named resolution mechanism to be specified
# the default order is "host lmhosts wins bcast". "host" means use the unix
# system gethostbyname() function call that will use either /etc/hosts OR
# DNS or NIS depending on the settings of /etc/host.config, /etc/nsswitch.conf
# and the /etc/resolv.conf file. "host" therefore is system configuration
# dependant. This parameter is most often of use to prevent DNS lookups
# in order to resolve NetBIOS names to IP Addresses. Use with care!
# The example below excludes use of name resolution for machines that are NOT
# on the local network segment
# - OR - are not deliberately to be known via lmhosts or via WINS.
; name resolve order = wins lmhosts bcast
# Windows Internet Name Serving Support Section:
# WINS Support - Tells the NMBD component of Samba to enable it's WINS Server
; wins support = yes
# WINS Server - Tells the NMBD components of Samba to be a WINS Client
# Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
; wins server = w.x.y.z
# WINS Proxy - Tells Samba to answer name resolution queries on
# behalf of a non WINS capable client, for this to work there must be
# at least one WINS Server on the network. The default is NO.
; wins proxy = yes
# DNS Proxy - tells Samba whether or not to try to resolve NetBIOS names
# via DNS nslookups. The built-in default for versions 1.9.17 is yes,
# this has been changed in version 1.9.18 to no.
dns proxy = no
# Case Preservation can be handy - system default is _no_
# NOTE: These can be set on a per share basis
preserve case = no
short preserve case = no
# Default case is normally upper case for all DOS files
default case = lower
# Be very careful with case sensitivity - it can break things!
; case sensitive = no
#============================ Share Definitions ==============================
[homes]
comment = Home Directories
browseable = no
writable = yes
[tmp]
comment = Temporary file space
path = /tmp
browseable = no
public = yes
# Un-comment the following and create the netlogon directory for Domain Logons
; [netlogon]
; comment = Network Logon Service
; path = /home/netlogon
; guest ok = yes
; writable = no
; share modes = no
# Un-comment the following to provide a specific roving profile share
# the default is to use the user's home directory
;[Profiles]
; path = /home/profiles
; browseable = no
; guest ok = yes
[printers]
comment = All Printers
path = /var/spool/samba
browseable = no
# Set public = yes to allow user 'guest account' to print
guest ok = no
printable = yes
Det enda som är ändrat från default är att jag har lagt till hybris som workgroup, caste prev.. och lagt till tmp som share.
8787Medlem sedan feb. 200330 inlägg
Har Du startat samba då....?
NephMedlem sedan apr. 200349 inlägg
Du försöker accessa din linux burk från en Win klient?
Om så är fallet
enabla Encrypted passwords
Lägg till ett Share ex. /mnt/cdrom
synka unix user & smb users
starta om smb
en lättare hantering kan vara https://www.webmin.com
Lycka till
Nej nej nej nej... ni är ute och cyklar båda två...
Jag visar från min telnetfönster
[root@linux daniel]# /etc/init.d/smb status
smbd är stoppad
nmbd är stoppad
[root@linux daniel]# /etc/init.d/smb start
Startar SMB-tjänster: [  OK  ]
Startar NMB-tjänster: [  OK  ]
smbd är stoppad
nmbd är stoppad
Den säjer alltså att den startar samba men den gör det ändå inte fastän jag är root.. :(
Aha
orsaken till att den inte startar är att något är felkonfat
stämmer interface IP med ditt smb interface ip?
[tmp] share kan vara fel utdelat..
står det något i loggen?
/var/log/messages
eller
/var/log/samba/
Var fel i hostfilen... nu ser jag den i windows men kommer inte åt den... ny utmaning...
Peter_BMedlem sedan apr. 2000642 inlägg
Slå på krypterade lösenord och skapa en smbpasswd-fil som du lägger samma användare som du loggar in i windows med.. med samma lösenord. Då funkar det för mig iaf ;)
Den säjer att "datorn inte tar emot begäran" fastän jag har slagit av krypterade lösen i windows...
eller hur ska jag göra för att få det att funka med DHCP inställningar.
Jag har bara instruktioner hur man gör med fasta IPn o sånt.
från smb.log
[2003/04/16 21:46:23, 1] smbd/process.c:process_smb(613)
Connection denied from 192.168.0.3
***fixade det... hade spärrat IPt i confen...****
Nu så vill den att jag fyller i lösen fastän jag har samma inlogg och namn på bägge ställena... kan det vara så att jag behöver plocka bort plain_password som jag la till i registret. Isf hur gör jag det?
För att sätta på (eller av) plain-password så har jag färdiga .reg filer här: http://trotter.hum.gu.se/pub/regfiles/
Det behövs inte med plain passwords
jag rekommenderar starkt att INTE använda det, stor säkerhets lucka med okrypterade lösen
installera webmin & kontrollera allt i Samba därifrån
Synka & lägga till SMB users går fort & enklet..
orsaken till att den inte accepterar är att den inte känner igen ditt username & passwd...
lycka till
129 ms totalt · 3 externa anrop · v20260731065814-full.86db40fa
