Projectviewer
2 svar · 264 visningar · startad av Kalle M
Jobbar en del i Ms Project.
Är det nån som vet om det finns nån enkel Project viewer?
Meningen är att projektdeltagare ska kunna gå in kolla utan att behöva Ms Project.
smidigast för alla om du gör en PDF av den.
View a project file Help
Assistance > Project 2003 > Viewing Project Information
Microsoft does not have a viewer program that enables you to open a project file from a computer that does not have Microsoft Office Project 2003 installed. However, if you do not have Project installed, or you have an earlier version of Project than the one with which the file was created, you can view the information in the file using a different method.
Note To learn more about the methods described in this topic, see the related links in the See Also list, which is visible when you are connected to the Internet.
View project information if you don't have Project installed
If you have Microsoft Office Project Web Access 2003, you can ask the project manager to publish the project and to give you permission to view the project. You can then view the project in Project Web Access.
If you don't have Project Web Access, but you can contact the file's creator, that person can distribute the information online.
If you don't have Project Web Access, and you cannot contact the file's creator, you can obtain a 60-day evaluation copy of Microsoft Office Project Standard 2003.
