Feltyp:
ADODB.Recordset (0x800A0E7D)
Åtgärden är inte tillåten på ett objekt som refererar till en stängd eller en ogiltig anslutning.
/login/login/login.asp, line 12
login.asp
Set RSUser = Server.CreateObject("ADODB.Recordset")
<!--#include file="../dbconnect.asp" -->
SQL = "Select * from t_Members Where f_User='" & Request.Form("Username") & "'"
RSUser.Open SQL,Connect,1,2
[b]If RSUser.EOF Then[/b]
User does not exist.
ElseIf RSUser("f_Password") <> Request.Form("Password") Then
Password is incorrect for<br>
<b><%=Request.Form("UserName")%></b>
Else
Session("User") = "Yes"
Session("UserID") = RSUser("f_ID")
Session("Admin") = RSUser("f_Admin")
Response.Redirect "admin.asp"
RSUser.close
Connect.close
258 ms totalt · 4 externa anrop · v20260731065814-full.d34c6d5a
