Meddelande
Minska
No announcement yet.
Problem med att ladda ner bilder med ftp?
Minska
  • Filter
  • Klockan
  • Show
  • Problem med att ladda ner bilder med ftp?
    När jag laddar ner bilder med denna kod, så får jag dem nog nedladdade med ftp, men t.ex Windows Photo Viewer kan inte visa dem korrekt utan blir ett rött kors istället.
    Här kommer koden, kan nån hjälpa mig?
    Jag fattar själv inte var felet finns.
    Kod:
     Private Sub ButtonSave_Click(sender As System.Object, e As System.EventArgs) Handles ButtonSave.Click
            Try
                Dim filearr() As String
                Dim filearr2() As String
                Dim filecheck As String
                Dim check, check2, j As Integer
                Dim myFtpWebRequest As FtpWebRequest
                Dim myFtpWebResponse As FtpWebResponse
                Dim myStreamWriter As StreamWriter
                Me.Cursor = Cursors.WaitCursor
                If My.Computer.FileSystem.DirectoryExists(PhotoApp.LabelOption4.Text + "\" + TreeViewftpdir.SelectedNode.Text) Then
                    MsgBox("Mappen finns redan!")
                Else
                    MkDir(PhotoApp.LabelOption4.Text + "\" + TreeViewftpdir.SelectedNode.Text)
                    Dim ftpWebReq As Net.FtpWebRequest = CType(Net.WebRequest.Create(PhotoApp.LabelOption3.Text + "/" + TreeViewftpdir.SelectedNode.Text + "/"), Net.FtpWebRequest)
                    ftpWebReq.Method = Net.WebRequestMethods.Ftp.ListDirectory
                    ftpWebReq.Credentials = New Net.NetworkCredential(PhotoApp.LabelOption.Text, PhotoApp.LabelOption2.Text)
                    Dim ftpWebResp As Net.FtpWebResponse = CType(ftpWebReq.GetResponse(), Net.FtpWebResponse)
                    Dim streamer As IO.Stream = ftpWebResp.GetResponseStream()
                    Dim reader As New IO.StreamReader(streamer)
                    check = 0
                    check2 = 0
                    MsgBox(PhotoApp.LabelOption3.Text + "/" + TreeViewftpdir.SelectedNode.Text + "/")
                    Do
                        filecheck = reader.ReadToEnd
                        If Len(filecheck) < 1 Then Exit Do
                        filearr2 = Split(filecheck, vbNewLine)
                        RichTextBox1.Text = filecheck
                        j = RichTextBox1.Lines.Count - 2
                        reader.Close()
                        Exit Do
                    Loop
                    For i As Integer = 0 To j
                        '   If PhotoApp.LabelOption3.Text + "/" + TreeViewftpdir.SelectedNode.Text + "/" + File.filearr2(check).get Then
                        myFtpWebRequest = WebRequest.Create(PhotoApp.LabelOption3.Text + "/" + TreeViewftpdir.SelectedNode.Text + "/" + filearr2(check))
                        myFtpWebRequest.Credentials = New Net.NetworkCredential(PhotoApp.LabelOption.Text, PhotoApp.LabelOption2.Text)
                        myFtpWebRequest.Method = Net.WebRequestMethods.Ftp.DownloadFile
                        myFtpWebRequest.UseBinary = True
                        myFtpWebResponse = myFtpWebRequest.GetResponse()
                        ' MsgBox(filearr2(check).ToString)
                        myStreamWriter = New StreamWriter(PhotoApp.LabelOption4.Text + "\" + TreeViewftpdir.SelectedNode.Text + "\" + filearr2(check))
                        myStreamWriter.Write(New StreamReader(myFtpWebResponse.GetResponseStream()).ReadToEnd)
                        myStreamWriter.Close()
                        myFtpWebResponse.Close()
                        check = check + 1
                    Next
                    Close()
                Me.Cursor = Cursors.Default
            Catch ex As WebException
                MsgBox("Serverinställningarna är felaktiga, kolla dem!")
            End Try
        End Sub
