Meddelande
Minska
No announcement yet.
JavascriptByggare (ASP.NET)
Minska
  • Filter
  • Klockan
  • Show
  • JavascriptByggare (ASP.NET)
    En application för att bygga ihop valda javascript ifrån en resourcefil.
    Kod:
    Imports System.Resources
    Imports System.ComponentModel
    Imports Dean.Edwards
    Namespace InovArt.Common
        Public Class JavascriptAssembler
            Private rm As ResourceManager = ResourceManager.CreateFileBasedResourceManager("scripts.JavaScripts", _
                HttpContext.Current.Server.MapPath("App_GlobalResources"), Nothing)
            Private sb As New StringBuilder
            Private WithEvents _page As Page
            Private _encode As ECMAScriptPacker.PackerEncoding = Nothing
            Dim L_reg As New Generic.List(Of String)
            Public Sub New(ByVal page As Page)
                _page = page
            End Sub
            Public Sub New(ByVal page As Page, ByVal Encoding As ECMAScriptPacker.PackerEncoding)
                Me.New(page)
                _encode = Encoding
            End Sub
            Protected Sub Pre_Render(ByVal sender As Object, ByVal e As System.EventArgs) Handles _page.PreRender
                _page.ClientScript.RegisterClientScriptBlock(_page.GetType, "RenderContent", RenderContent, True)
                '_page.Trace.Warn("Write Javascript")
            End Sub
            <Description("Adds resource value based on the resource name parameter")> _
            Public Sub AddScript(ByVal ResourceName As String)
                If Not isScriptRegistred(ResourceName) Then
                    RenderContent = rm.GetString(ResourceName)
                    RegisterScript(ResourceName)
            End Sub
            <Description("Adds resource values based on the resource name parameter")> _
            Public Sub AddScript(ByVal ResourceNames As String())
                For i As Integer = 0 To ResourceNames.Length - 1
                    AddScript(ResourceNames(i))
                Next
            End Sub
            <Description("Adds a custom script as a string. The ´Name´-variable handles the registration.")> _
            Public Sub AddScript(ByVal Script As String, ByVal Name As String)
                If Not isScriptRegistred(Name) Then
                    RenderContent = Script
                    RegisterScript(Name)
            End Sub
            Private Property RenderContent() As String
                Set(ByVal value As String)
                    sb.AppendLine(value)
                End Set
                Get
                    If Not Me._encode = Nothing Then Return Obfuscate(sb.ToString())
                    Return sb.ToString()
                End Get
            End Property
            Private Function Obfuscate(ByVal str As String) As String
                Dim obfuscator As New ECMAScriptPacker()
                obfuscator.Encoding = _encode
                obfuscator.SpecialChars = True
                Return obfuscator.Pack(str)
            End Function
            Private Sub RegisterScript(ByVal str As String)
                L_reg.Add(str)
            End Sub
            Private Function isScriptRegistred(ByVal str As String) As Boolean
                Return L_reg.Contains(str)
            End Function
        End Class
    End Namespace
    Maskinöversatt till C#:
    Kod:
    using System.Resources;
    using System.ComponentModel;
    using Dean.Edwards;
    namespace InovArt.Common
        public class JavascriptAssembler
            private ResourceManager rm = ResourceManager.CreateFileBasedResourceManager("scripts.JavaScripts", HttpContext.Current.Server.MapPath("App_GlobalResources"), null);
            private StringBuilder sb = new StringBuilder();
            private Page _page;
            private ECMAScriptPacker.PackerEncoding _encode = null;
            Generic.List<string> L_reg = new Generic.List<string>();
            public JavascriptAssembler(Page page)
                _page = page;
            public JavascriptAssembler(Page page, ECMAScriptPacker.PackerEncoding Encoding) : this(page)
                _encode = Encoding;
            protected void Pre_Render(object sender, System.EventArgs e)
                _page.ClientScript.RegisterClientScriptBlock(_page.GetType, "RenderContent", RenderContent, true);
                //_page.Trace.Warn("Write Javascript")
            [Description("Adds resource value based on the resource name parameter")]
            public void AddScript(string ResourceName)
                if (!isScriptRegistred(ResourceName)) {
                    RenderContent = rm.GetString(ResourceName);
                    RegisterScript(ResourceName);
            [Description("Adds resource values based on the resource name parameter")]
            public void AddScript(string[] ResourceNames)
                for (int i = 0; i <= ResourceNames.Length - 1; i++) {
                    AddScript(ResourceNames(i));
            [Description("Adds a custom script as a string. The ´Name´-variable handles the registration.")]
            public void AddScript(string Script, string Name)
                if (!isScriptRegistred(Name)) {
                    RenderContent = Script;
                    RegisterScript(Name);
            private string RenderContent {
                get {
                    if (!(this._encode == null))
                        return Obfuscate(sb.ToString());
                    return sb.ToString();
                set { sb.AppendLine(value); }
            private string Obfuscate(string str)
                ECMAScriptPacker obfuscator = new ECMAScriptPacker();
                obfuscator.Encoding = _encode;
                obfuscator.SpecialChars = true;
                return obfuscator.Pack(str);
            private void RegisterScript(string str)
                L_reg.Add(str);
            private bool isScriptRegistred(string str)
                return L_reg.Contains(str);
    Implementeras så hära:
    Kod:
    'Utan Obfuscator
    Dim jsa As New JavascriptAssembler(Me.Page)
    'Med Obfuscator
    Dim jsa As New JavascriptAssembler(Me.Page, Dean.Edwards.ECMAScriptPacker.PackerEncoding.None)
    'Som string() från Resourcefilen
    Dim functions As String() = {"getCookie", "PreLoadImages", "setCookie"}
    jsa.AddScript(functions)
    'Som string från Resourcefilen
    jsa.AddScript("Funktion")
    'Som Custom (Inte resourcefilen)
    jsa.AddScript("funktion egen(){//content};", "Eget_Namn")
    Kod:
    //Utan Obfuscator
        JavascriptAssembler jsa = new JavascriptAssembler(this.Page);
        //Med Obfuscator
        JavascriptAssembler jsa = new JavascriptAssembler(this.Page, Dean.Edwards.ECMAScriptPacker.PackerEncoding.None);
        //Som string() från Resourcefilen
        string[] functions = {"getCookie", "PreLoadImages", "setCookie"};
        jsa.AddScript(functions);
        //Som string från Resourcefilen
        jsa.AddScript("Funktion");
        //Som Custom (Inte resourcefilen)
        jsa.AddScript("funktion egen(){//content};", "Eget_Namn");
    Vill gärna ha kritik på denna applikation.
    I denna tråd.
    Bifogade filer
    3
    Host...kastas i papperskorgen
    33.33%
    1
    Bra-å-ha-sak
    66.67%
    2
    Exakt vad jag behövde
    0.00%
    0
    Last edited by Jesper T; 2007-12-12, 19:58. Anledning: Lagt till översättning till C#
    Vänligen Jesper
    Etisk kommunikation
